Author Subject: Getting to the washer bottle
Kenan
My washer bottle has developed a leak, whats the best way of getting to it to locate the fault? Is it behind the inner wheel arch and if so how do I get it off Crazy
Posted 13th Nov 2017 at 19:11
pug_306
Easier if you remove drivers wheel. Then 2 x torx screws and a clip will give you access to the 2 x 10mm nuts. Also you need to unscrew the filler neck before you remove it ;-)
1992 205 GTi6
205 Turbo 340bhp
Posted 13th Nov 2017 at 19:13
Kenan
Thanks Ryan, once I'v had a look I'm sure I'll be asking you for a replacement bottle !!!!
Posted 13th Nov 2017 at 19:18
pug_306
No worrys buddy. Probably from the washer pump seal.
1992 205 GTi6
205 Turbo 340bhp
Posted 13th Nov 2017 at 19:24
