Author Subject: misfire...
barrym
Hi all,
My car has just developed a misfire. It's slight on idle and not too bad revving in neutral, but gets worse under load. There is a strong smell of fuel out of the exhaust too. I'm guessing it's ignition related: coil pack or associated wiring, maybe plugs but they are just a few weeks old.
I have just ordered a set of coil packs from pug_306 and TBH I haven't done any real investigating as it's dark.
No other issues, gauges behave normally, coolant level and temps fine etc.
I will dig around a bit tomorrow by pulling coil pack plugs.
I know it is hard to say but do you think I am looking in the right direction?
Black Rallye occassional toy
Posted 31st Oct 2017 at 17:19
check plugs are tight, do a compression test.
Posted 31st Oct 2017 at 18:22
pug_306
I would stick a new set of plugs in if your changing the coil packs buddy but it's more than likely a coil pack at fault.
1992 205 GTi6
205 Turbo 340bhp
Posted 31st Oct 2017 at 18:29
barrym
Thanks, will check the plugs. I was planning to pull them out anyway to inspect them. TBH I don't have the means to test compression and the coil packs will arrive soon so will fit it/them first. If that doesn't cure it then will def get comp checked.
The car did develop a similar misfire that was cured by new the plugs so hoping that just masked a ropey coil pack. We will see.....
Posted 31st Oct 2017 at 18:33
barrym
Update....replaced coil packs and plugs, still the same. Car is now with my mechanic for compression test
Posted 2nd Nov 2017 at 17:19
pug_306
Did you unplug a coil or injector while running to see which cylinder it was ?
1992 205 GTi6
205 Turbo 340bhp
Posted 2nd Nov 2017 at 17:21
barrym
TBH mate I didn't. I picked the coil packs up on my way home today, thanks for the excellent service as always, and it was a race between me and the failing light to get them fitted. Would have liked to do a better job diagnosing the problem but also had the hard deadline of my mechanic closing for the day and not being able to get a courtesy car.
Posted 2nd Nov 2017 at 17:33
Cjwatson27
Too late to check now but could be a earthing issue
Posted 2nd Nov 2017 at 19:25
barrym
Picked the car up today. Head gasket had failed between cylinders. Had full cambelt kit and water pump fitted at same time. She lives on
Posted 9th Nov 2017 at 12:18
