Author Subject: Subframe mount and bolts
blandy
I'm after a subframe mount/bolt - sits between the subframe and the chassis at the front held to the car with 2 m8 bolts and 1 large bolt that bolts the frame to that.... my bolt sheared in the mount
Posted 18th Sep 2017 at 10:28
Cjwatson27
I might have one
Posted 18th Sep 2017 at 10:30
miki4
What do you need from these?
miki4 has attached the following image:
Posted 18th Sep 2017 at 10:35
pug_306
Look at this on eBay  http://www.ebay.co.uk/itm/132170828079
Will do you a pair for £20inc del ;-)
1992 205 GTi6
205 Turbo 340bhp
Posted 18th Sep 2017 at 10:46
Rich E Forum Admin
The nut that sits in the centre of the cup is still available new from Peugeot, along with the bolt (parts 6 and 4 in the drawing above)
Should be able to get them from a dealer for under a tenner for both.
Posted 18th Sep 2017 at 13:41
blandy
In the pic it's items 4 5 2 6
Only need the one side As bolt sheared on Sunday
Posted 18th Sep 2017 at 14:06
pug_306
2 is NLA when I tried to buy around 3 months ago.
1992 205 GTi6
205 Turbo 340bhp
Posted 18th Sep 2017 at 14:45
lj_6
No.4 is also NLA. That was two years ago Aswell!
Astra burg #365 Garrett Power
'99 bodied 6 track project
Posted 18th Sep 2017 at 14:51
Rich E Forum Admin
4 isn't listed NFP on Servicebox. There's an earlier revision of it that's NFP but 3509 56 should still be available.
Unless the cup has been cut off or chucked away already I don't see why any more than 4 and 6 should be needed?
Posted 18th Sep 2017 at 15:24
Ben_W
Formerly gpm
If it's anything like the ones I just took off the 6 I broke, then that may not be the case Rich.
The subframe cup was so full of corrosion that it had filled the gap between cup and castle nut (part 6). It wasn't coming out without a fight...
On a lighter note, I may have located some more new cups.
Posted 18th Sep 2017 at 15:36
