Author Subject: gti6 conversion question
topcon@indigo.ie
Hi i have put a gti6 in a 309 all is good have it running but cant get the oil pressure guage working i fitted a 205 sender in the block and have the 30b wire going to the sender but what voltage should i see at the sender as i have a very low voltage. also in my gti6 loom i have no vss plug any ideas.
Posted 28th Aug 2017 at 12:56
fatlapit
Give miles horne a ring at pug racing dude
Posted 28th Aug 2017 at 15:39
Do you need the speedo sensor plug ? If so you need to get a sensor that has the electrical plug and the mexhanicall part as well - I forget which car it comes from ??
Posted 28th Aug 2017 at 17:04
earth the wire to the block and see if the gauge goes to the top.
Posted 28th Aug 2017 at 19:29
you say you have no vss plug, do you mean its missing and the wires are dangling? if so you need a white 3 pin jpt plug, same as the tps so easy to find in a breakers.
or is the sensor missing in the speedo drive? theres lots of dual mechanical and electronic type vss's on ebay as used by the s16 but not exclusively.
Posted 28th Aug 2017 at 19:32
topcon@indigo.ie
i did ground it and nothing this is my concern where all the other sensors i got working i would have thought i would have about 5v at the end of the wire. i took it striaght from the dash 30b wire
Posted 28th Aug 2017 at 20:16
topcon@indigo.ie
i have the part for the gearbox got that but on my loom i dont have the vss cable its not there only noticed when i had the whole loom installed.
Posted 28th Aug 2017 at 20:17
