Author Subject: Genuine cat
I'm after a genuine cat in good condition. Anybody got one? If so, how much delivered?
Posted 22nd Aug 2017 at 22:50
RetroPug
I've got a genuine cat which has had the typical outlet pipe snapping failure. Before it did that it was passing MOTs fine. It came off the car a year and a bit ago or so. Car had covered 60ish k at that point.
I bought another used one, converted it to a sleeved joint to fit my existing system and then swapped them over. The same could be done with this one.
£75 seems to be roughly what they are worth to weigh in from looking back on other threads. So £75 plus postage seems reasonable?
If you want one with an intact outlet no worries
Posted 23rd Aug 2017 at 13:07
I'll hang fire for a little bit incase an intact one comes up, if not i will probably take you up on this.
Mine is still functioning but it seems to be on its way out at the flange where it meets the centre section, i was hoping to just get under the car and do a swap and keep this one as a spare rather than go somewhere and have this one repaired.
Cheers. Smile
Posted 24th Aug 2017 at 18:00
RetroPug
That basically what happened to mine, and then it snapped at Curborough.
The same failure happened on my old 306 as well.
No worries, let me know.
Posted 24th Aug 2017 at 20:56
