Author Subject: Alternative to throttle bodies.
Flatoutfarr
Guys
Thinking ahead for next season and potential engine mods, I saw the ad for the 106 rally-cross car that had R1 carbs on a GTI-6 engine.
Has anyone else gone down this route and where do you source suitable inlet manifolds etc ? Any pics/info?
I was looking at trying to up my power to circa 200bhp but have realised that the standard injection system will not allow that sort of power output. I am used to twin 45DCOE's [joys of being an old git]
Adventure before Dementia !!
Posted 10th Jul 2017 at 09:22
There's an old thread on here by a lad called yanni if memory serves right, he used some r1 bodies on a standard cut down manifold iirc.
Posted 10th Jul 2017 at 10:33
costs to do it properly are much the same as an off the shelf satchell inlet and jenvey bodies.
if youre a competent fabricator machinist and welder then crack on, if not, get the satchell inlet and DCOE bodies and an ecu to suit.
Posted 10th Jul 2017 at 10:36
standard injection system wil do 200 just fine (with a map obviously)
however the spec of engine you need to build to produce those numbers is somewhat higher than a set of mild cams when you run throttle bodies.
Posted 10th Jul 2017 at 10:37
