Author Subject: Fuel pressure sensor
What fuel pressure sensors are people using and where are they plumbing them in?
Posted 8th Jul 2017 at 08:59
not using one, you can get a temporary test gauge to fit inline quite easily from torques.co.uk, not made for permanent installation though.
stack do electric ones but the sender alone is about £100!
Posted 8th Jul 2017 at 12:08
I might just have to get one of them torques ones and some adapters then, looks like a £35 investment.
I'm assuming with a correctly functioning fuel pressure regulator the high pressure hose to the rail should read 3 bar at all times?
I might make a rubber extension hose and run it to the gauge in the car as a temporary measure so I can see the reading if I go on a test drive.
Posted 8th Jul 2017 at 19:19
miki4
3 bar compared to inlet manifold pressure.
Posted 8th Jul 2017 at 20:02
