Author Subject: Missfire at 4k
fatlapit
So i have a strange miss fire at 4k.
Regardless of temp
Regardless of load/gear
Regardless of speed
Regardless of boost level
Ive tried a new coil unit made no difference
Tried a new map sensor made no difference
Tried new plugs no difference
Tried a tps no difference
So any ideas??
Posted 2nd Jul 2017 at 19:07
fatlapit
Oh fpr is fpot on too
fatlapit
On omex 600 too
Posted 2nd Jul 2017 at 19:08
Is the lambda giving the right readings?
Does it go away higher up the revs?
Posted 2nd Jul 2017 at 20:21
fatlapit
Literally only 4k. Clean before and clean after. The plugs look great and we couldnt fix it on the dyno either. Its like it just cba at 4k
Posted 2nd Jul 2017 at 20:43
fatlapit
Also it revs freely when in neutral
Posted 2nd Jul 2017 at 21:00
miki4
Is it also missing while accelerating full chat and passing 4K or only when holding it at 4K? Does it miss on part throttle while passing 4K?
Posted 2nd Jul 2017 at 21:59
fatlapit
Misses at 4k whilst driving at any throttle position but is perfectly clear before and after and will rev freely in neutral
Posted 2nd Jul 2017 at 22:20
miki4
A dodgy crank or cam position sensor that gives false readings at around 4k would be plausible. Also check the loom and plugs of those sensors. Could be that right at that revs some interference occurs in the signal path. Can you read live sensor data? Has the fault developed or has it always been there in this config?
Posted 2nd Jul 2017 at 23:19
fatlapit
developed about a month ago, thought we may of sorted it on the dyno but to no avail
Posted 3rd Jul 2017 at 07:55
can you get a capture of the datalog the ecu is seeing when it happens?
do you run a knock sensor?
Posted 3rd Jul 2017 at 11:00
fatlapit
No nock sensor
Ill plug my laptop in and see but when it was on the dyno it pointed at a coil issue. However ive swapped the coil for a new one which made it worse.
The plugs are new and have been gapped
Posted 3rd Jul 2017 at 11:37
what coil do you use? reputable brand?
Posted 3rd Jul 2017 at 12:24
fatlapit
yeah man its a s16 coil dude
Posted 3rd Jul 2017 at 12:34
fatlapit
I will try a new coil
ohhh I see, yeah they were buggers for misfires even if they looked fine, have you trimmed the cam cover back to allow the heat to escape? or is it modified onto a gti6 head?
Posted 3rd Jul 2017 at 12:44
fatlapit
gti6 head has been modded to accept the coil
Posted 3rd Jul 2017 at 13:01
