Author Subject: 205 engine mount help
3rd time lucky
Hi guys. I know some of you are knowledgeable with 205's so hopefully one of you can help. Basically, I've got a serious problem. I've had the upper rubber engine mount snap. There were 2 bolts holding the mount bracket to the side of the block, 1 was completely undone and the other has snapped in the block. Can someone tell me if there are other bolt holes I can use because it looks like there is another one which has not been used, possibly causing this failure. Any help is appreciated Thumbs up
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 26th Feb 2017 at 10:00
thats xud9te so not specific to a 205, never seen that happen so its likely due to a missing bolt, they can't just fall out due to the proximity of the chassis leg.
there should be 4 bolts, don't think they are the same length.
Posted 26th Feb 2017 at 10:43
3rd time lucky
It has been messed around with quite a lot so I suspect someone got lazy and didn't put all the bolts in. At the time of failure, it looks like only one was actually in place as that is the one that has snapped when the engine mount split in half.
BLACK RALLYE - Sold
Posted 26th Feb 2017 at 11:11
Probably quicker to take the engine out to investigate and repair properly, the timing belt tensioner spring plunger is housed in the bottom of that casting, itll make fitting a new belt kit a 5 min job too.
Posted 26th Feb 2017 at 11:47
This is good advice, unfortunate you have to do it but realistically the best way forwards.
Posted 26th Feb 2017 at 15:33
3rd time lucky
Not really ideal as Pete is hopefully coming over Wednesday eve to put a cambelt on it and hopefully get it back on the road. I know it's quite a big ask from him but I'm sure he is capable.
Mei, do you know what size the mount bracket bolts are...?
BLACK RALLYE - Sold
Posted 26th Feb 2017 at 21:33
IIRC its M8 bolts, not sure on length, I believe it changed at a certain date.
Posted 26th Feb 2017 at 21:58
3rd time lucky
Ok bud, cheers Thumbs up
BLACK RALLYE - Sold
Posted 27th Feb 2017 at 00:03
3rd time lucky
Pete did fix this. New engine mount, and cambelt/ water pump. Only took him couple hours too Thumbs up
BLACK RALLYE - Sold
Posted 30th May 2017 at 16:17
