Has anyone tried to wrap the cable with heat warp or similar to try to keep the heat away to make the grease last longer?
| Author | Subject: Clutch Cable Heat Wrap |
Kenan
Regular Location: Exmouth Registered: 20 Oct 2013 Posts: 307 Status: Offline |
Thinking my clutch could do with changing, only so many times I can put WD40 on it...Has anyone tried to wrap the cable with heat warp or similar to try to keep the heat away to make the grease last longer? |
fatlapit
Ive never had a bother with mine. Is it clipped to the subframe??________________________________________ |
Kenan
fatlapit wrote: Ive never had a bother with mine. Is it clipped to the subframe?? I hope so, but not checked. Was thinking to try wrapping when I change it. |
proper spec gti6 cables have a section of heat wrap on already________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
