I already run 205 but with the camber its a bit tight especially on the rear.
| Author | Subject: 225 width? |
fatlapit
has anyone ever ran this wide? if so did you do body modifications??I already run 205 but with the camber its a bit tight especially on the rear. Cheers Chris ________________________________________ |
fatlapit wrote: has anyone ever ran this wide? if so did you do body modifications?? I already run 205 but with the camber its a bit tight especially on the rear. Cheers Chris What size & profile ? Thought you normally run 17s ? |
fatlapit
yeah be like a 225 40/45 17________________________________________ |
fatlapit
with new developments mainly in the transmission and diff area I think im gonna need more grip________________________________________ |
fatlapit wrote: with new developments mainly in the transmission and diff area I think im gonna need more grip I ran pilot Sport 2=225/40/17s on 30mm drop on my Diect fit Mo5s in the early days & they hit my inner wall pan both sides & caught my 6 speed box badly ...but you run a 5speed ? They never had enough side wall movement for me personally ... The more grip & more chances of breaking that new box or Diff or driveshafts ....205s for my Minimal 293 N/A is perfect it's going to break the weakest point with too much grip |
fatlapit
yeah im on 5 speed.im just worried with the reduced fd and shorter ratios its gonna spin, maybe look at boost by gear ________________________________________ |
What's the FD -On 5speed ?If you have it to bad .....you'll be pulling away in 2nd |
fatlapit
enough to give me 143 mph @ 7200 in 5th its near a 1900 205 gti ratio________________________________________ |
RallyeRed
Regular Location: Northwich Registered: 03 May 2016 Posts: 353 Status: Offline |
215 is always an option in decent track day rubber.. |
fatlapit
Cheers dude________________________________________ |
fast_eddie
Regular Location: bradford Registered: 21 Jan 2012 Posts: 285 Status: Offline |
Has anyone actually done a best fit spread sheet for gear boxes for the 6?IE ratios from other boxes etc and final drives? I dont need to do 130 on a private strip in 6th, but it might be nice to do that in 5th at the right rpm? |
fast_eddie wrote: Has anyone actually done a best fit spread sheet for gear boxes for the 6? IE ratios from other boxes etc and final drives? I dont need to do 130 on a private strip in 6th, but it might be nice to do that in 5th at the right rpm? In my 6 with a 6speed box & 205/50/16 tyres with 4.75 Bacci Romani Crownwheel & pinion @ 8500rpm I'm doing 126 max in 5th ...never really use 6th on track yet ? |
without spending bug money you wont get any other gear ratios for a gti6 box, you can get a final drive though.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
Damien i would of thought ud use 6th at coombe________________________________________ |
