If so do they hold up to the job fine and where did you get them from?
Seen them advertised a few places but first hand reviews always help.
| Author | Subject: Nyloc hub nuts |
devere
Senior User Location: Saxtead Registered: 16 Dec 2008 Posts: 810 Status: Offline |
Anyone on here using nyloc hub nuts rather than a castle nut and split pin?If so do they hold up to the job fine and where did you get them from? Seen them advertised a few places but first hand reviews always help. |
yes, Garry has them on his car, they'll be the same for yours.I think Tom Fenton on the 205 forum has some, places like AB charge loads for them! ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
devere
He sells them on there does he?I shall see if I can remember my login for there and track him down! |
fatlapit
what size is the nut________________________________________ |
M24x1.5, I checked with Calvin and it was Tom indeed.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
fatlapit
hmmmm may have some @ work________________________________________ |
devere
So are they a specific nut, or without sounding too cowboy, will any m24x1.5 nyloc nut do the business? |
miki4
Regular Location: Cologne Registered: 09 Nov 2015 Posts: 393 Status: Offline |
What's wrong with the original nut and split pin? |
its a faff when you want to change a shaft quickly in service and get back out without any time penalties.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
miki4
Sorry, I don't get it. I'm no native speaker. Can you reformulate your sentence please? ![]() The only issue I had was the socket size. 35 mm is not common and I could not get it in any local store. I helped myself with a 36 spanner and lined it with pieces of a 0.5 feeler gauge in three places. Best tip ever! |
35mm is very common, probably on 99% of psa vehicles on the road.Nyloc type nuts are used to speed up service time on stage rallies ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
miki4
Ah okay, now I understand. Thanks |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Down side is a nylon lock nut "should" be one time use only |
