S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired
Author | Subject: Nearside Hub with 18mm Balljoint |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
I've had a new bearing fitted but there is still play so need a hub with good bearing for a phase 2.Cheers ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Posted 19th Nov 2016 at 15:40
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
16mm or 18mm ? |
Posted 18th Nov 2016 at 11:23
Capt Pedantic Location: Bigend, Wales. Registered: 27 Mar 2007 Posts: 25,839 Status: Offline |
tightened the hub nut yet?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Posted 18th Nov 2016 at 12:54
cully wrote: 16mm or 18mm ? What's the standard size for a phase 2? ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Posted 18th Nov 2016 at 14:13
welshpug! wrote: tightened the hub nut yet? Yes, fully torqued up! ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Posted 18th Nov 2016 at 14:14
cully
rudolf wrote: cully wrote: 16mm or 18mm ? What's the standard size for a phase 2? only real way to tell is measure the balljoint Ph2 could have both size's many Ph2 have been changed to 18mm even if they started life as 16mm like my own |
Posted 18th Nov 2016 at 16:58
cully wrote: rudolf wrote: cully wrote: 16mm or 18mm ? What's the standard size for a phase 2? only real way to tell is measure the balljoint Ph2 could have both size's many Ph2 have been changed to 18mm even if they started life as 16mm like my own I'll have a check tomorrow. Have you a spare one? ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Posted 18th Nov 2016 at 19:26
cully
no i dont sorry |
Posted 18th Nov 2016 at 19:49
Service Box says it is 18mm________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
I need this urgently, anyone?________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
Posted 20th Nov 2016 at 09:45
