S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired
| Author | Subject: ECU |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
I've removed the bracket that slides it into the plastic box, but how do I remove the base to get inside?________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
heat gun the sealant then prise off the tin cover |
Thanks.Do I need to heat it up again to put the cover back on or need to use silicon sealant? ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
cully
dig it out use new sealant |
