Author Subject: vacuum pump blanking plate
anyone on here got a vacuum pump blanking plate going or know who does them? i know Spoox do them but thought someone else did Unsure
yes i could make my own but testing the water first
i could probably blank the inlet off actually and keep the pump so might not even need it
thanks muchly
Posted 4th Oct 2016 at 13:27
Don't see the point if you want to do away with it sapping power from the camshaft just remove the key that sits between it and the cam and run the pipe from.the servo straight to the inlet.
Posted 4th Oct 2016 at 13:36
id keep it, especially if you are on throttle bodies or boost
Posted 4th Oct 2016 at 13:39
cully
question?
if your removing the vac pump will you also need to blank the cam oil feed to the pump?
Posted 4th Oct 2016 at 14:01
i've changed my mind. i'm going to blank the inlet and run the vac pump direct to the servo
so dis fred is scrap now innit
Posted 4th Oct 2016 at 14:15
cully wrote:
question?
yes you would.
Posted 4th Oct 2016 at 16:02
