Author Subject: Starting issue when hot
deeturbo
Hi,
When I try starting the car after a run I find that it doesn't sound that it sound it starts as it does when it's cold. It sounds like a lazy start. The starter does spin at normal speed but the way it fires doesn't sound right to me.
Is this normal?
Just thought I'd ask about this in case it gets worse.
Posted 11th Sep 2016 at 18:23
tvrfan007
Coolant temp sensor. Always do it when it's been used?
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 11th Sep 2016 at 21:55
deeturbo
Three sensors, is one for the fans, one the ECU and other for the gauge?
Should all of them have the same resistance?
So would the one the ECU uses be going out in my case?
Posted 12th Sep 2016 at 13:08
miki4
Did you sort it out? I've had the same problem since I bought the car. Coolant temperature reads out fine via PP2000 and is plausible though. Only fault code I have is in the A/C ECU: "Permanent fault. Coolant temperature sensor" or something like this.
Posted 16th Sep 2016 at 19:48
