displaying posts 1 to 25 of 31
Author Subject: Sparco subframe bucket correct number
bak
I need a subframe for my sparco bucket seat.
I saw on internet that the Sparco reference for our cars and Citroen ZX was 499054. But I read on spanish forums that reference did not fit propperly to the 306 and they said the correct number is 499049 which appears on internet for the Citroen AX/Saxo an Peugeot 106
I wanted fit the subframe to the original bolts without modifications
Does anyone really knows which of the two numbers fit to our cars?
Remember that we drive on the wrong side Razz and our driver seat is your passanger seat Thumbs up
Posted 6th Jun 2016 at 09:27
Chr1sch
the ones advertised on the Demon Tweeks website under 306 fit perfectly (I have 2 in mine) and use the factory bolts etc.
Posted 6th Jun 2016 at 10:27
bak
So, this Sparco with 499054 reference number fit perfect as driver or passanger seat, isn't it?
http://www.demon-tweeks.co.uk/performance/seat-mounting-frames-vehicle-specific/car/peugeot/306-phase-3-gti-6/2000/sparco-tailored-seat-subframe
Thanks in advance Wink
Posted 6th Jun 2016 at 11:17
bak
Another experience?
On spanish forums they say me again that I need weld a little piece of metal to fit perfectly the 499054 seat subframe and the AX/Saxos/106 with the reference 499049 fit perfect
Posted 7th Jun 2016 at 10:13
Chr1sch
That's the right one yes although that picture is wrong...
Posted 7th Jun 2016 at 13:02
bak
Thank you mate Wink I will buy the reference that you hace
Posted 7th Jun 2016 at 15:20
craig903
With these subframes do the bucket seats sit with the wheel directly in the center of them?
208 GTI Owner
Posted 7th Jun 2016 at 17:50
bak
I have just recieved the sparco subframe, and they do not fit in my car. The side bolts measure in my car is 35cm and the subframe measure is only 31cm
Furthermore the subframe holes do not fit into the 306 tunnel so I will make new holes if I would install the bucket
Posted 23rd Jun 2016 at 06:41
Chr1sch
there are 2 parts to it, the main frame, plus an L shape bracket that bolts to the car - have you got both bits?
Posted 23rd Jun 2016 at 17:06
bak
Yes, I have them but the holes are too near
Posted 23rd Jun 2016 at 18:34
pugheaven
Mine fit perfectly using the same part number 00499054
Posted 23rd Jun 2016 at 18:40
Cjwatson27
Has this helped lower the driving position ?
Posted 23rd Jun 2016 at 18:48
pugheaven
Depends if your using side mounts, with my seat in the lowest position on the side mounts my seat sits lower than the subframes due to the design of the subframe where they drop down in the middle with the u shaped bars.... if that makes sense
Posted 23rd Jun 2016 at 19:19
Cjwatson27
Ha not really I want to lower my seat not sure if it's worth cutting all the mounts out and welding in some seat bars. Or wether to get some of these
Posted 23rd Jun 2016 at 19:27
pugheaven
If you have seen the subframes you will see that the bars going from inboard to outboard are lower than the brackets you mount to the exhaust tunnel and sill, with the seat in the lowest position on the side mounts the bottom of the seats go below the height of the exhaust tunnel
Posted 23rd Jun 2016 at 19:30
Cjwatson27
Right I've got you now thanks what seats are you using ? Sorry for the thread hijack
Posted 23rd Jun 2016 at 19:35
pugheaven
Corbeau revolutions
Posted 23rd Jun 2016 at 19:52
bak
I will send you the pics tomorrow to check the fault
Posted 23rd Jun 2016 at 23:02
bak
Posted 23rd Jun 2016 at 23:03
bak
Closer: The holes do not match
Posted 23rd Jun 2016 at 23:17
bak
The original measure between side holes
Posted 23rd Jun 2016 at 23:07
bak
The Sparco subframe measure
pugheaven
Try loosely assembling it and doing up the 2 bolts by the door last, if not fit spacers or washers to the 2 bolts by the door to allow alignment
Posted 23rd Jun 2016 at 23:08
bak
The Sparco instructions include inside the subframe package
bak
That's all XD
I do not know whats is the different between the spanish cars and GB cars (moreover the driver side) but as you can check, that is not fit into my car
Posted 23rd Jun 2016 at 23:10
