Author Subject: Oil Cooler
arigti6
My Rallye has the single fan, I'm assuming I'd be better off changing to the double fan setup with the addition of an oil cooler. Also any pics or link to a thread to see how best to fit/plum oil cooler in would be great!
Thanks in advance
Ari. Smile
I Live for the 306 Ninja
TEAM CHERRY PINK RALLYE
2008 BMW ///M 320d
Posted 26th May 2016 at 10:48
single fan is fine, no need for an oil cooler unless you're having oil temp issues on track?
Posted 26th May 2016 at 11:41
sergioiacobucci
I've been thinking about oil cooler but first need fine an accurate way of measuring oil temp
Phase 1 silver track car
335i daily
Posted 26th May 2016 at 12:20
standard oil temp gauge is fine.
Posted 26th May 2016 at 12:31
3rd time lucky
I think the second fan on the Gti-6's is mainly for the air-con iirc.
BLACK RALLYE - Sold
CHERRY RALLYE - new toy
Posted 26th May 2016 at 13:01
aaron6
Yep. All non ac cars had one fan and are fine. You will have oil temp issues on track. I've up'd mine from a 13 to 16 row as mine was still a bit warm at Brandshatch.
Posted 26th May 2016 at 13:13
Yup unless it's been messed with the standard one on a phase 2 /3 6 instrument cluster works well.
Posted 26th May 2016 at 13:17
Fans are redundant once the car is moving, they don't do anything past about 30mph, if you want more cooling get an oil cooler, not an extra fan.
Posted 26th May 2016 at 13:31
manthos
It's because Rallyes are a poverty spec gti6 they didn't come with everything on them. Only one fan, no air con, poverty cloth interior, less paint and they never even came with the option of a sunroof either.
Team SUPERCHARGED
Old Project thread
Posted 26th May 2016 at 13:35
fatlapit
Manthos knows the crack good lad
Posted 26th May 2016 at 15:20
sergioiacobucci
Do phase 1's have this? I think I only have oil pressure?
335i daily
Posted 26th May 2016 at 16:07
arigti6
I understand that the Rallye had the single fan for not having A/C but I'm thinking of upgrading as the temp shot up in traffic either that or I may have to have a manual switch?
So if I want to use it for the odd track day I won't necessarily need oil cooler?
2008 BMW ///M 320d
Posted 26th May 2016 at 23:38
RetroPug
That's correct, ph.1s don't have it.
Posted 26th May 2016 at 23:46
As 3rd time lucky said the second fans only for Aircon m8
Harry as Mei said fit a oil cooler if you only have oil temp issues m8 ...I only needed one when I when on track for lap after lap on warm days m8 ....but I've got one for sell a 16row with Mocal sand which plate & two goodridge Stainless steel hoses ready
to fit if you end up needing one m8 ...
These boys know there stuff Harry listen to them m8
Posted 28th May 2016 at 08:19
manthos
Thumbs up
Team SUPERCHARGED
Old Project thread
Posted 27th May 2016 at 14:56
ale624
How hot we talking?
If your car starts overheating in traffic could be a head gasket. My 106 started doing that and it totally crapped out about 200 miles later.
Check your coolant levels and top up!
Posted 27th May 2016 at 15:55
aaron6
Should get to about 97°c on the water
Posted 27th May 2016 at 23:21
I have a 19 row oil cooler on mine and the oil gets up 95c on track, when I had a 13 row it used to climb to 120c. Makes a big difference.
Posted 28th May 2016 at 00:41
