Author Subject: Servo problems? + how to remove?
ben tearle
Right then, I've been having a nightmare with my trackday GTi6, all new discs and pads just fitted all round, fluid changed, it was bled many many times, but the pedal kept going to the floor slowly.
Vacuum hose's from the servo all checked the jubilee clips checked for tightness.
I then changed the master cylinder for another one, no change.
I then cracked off the two pipes I could get on at the rear compensator as you could hear trapped air, the pedal went nice and solid, I thought great that's it sorted.......start the engine and the pedal goes to the floor...
When you search on here/google it all points towards the servo being at fault?
Has anyone changed one recently? It doesn't look like it'll come out easily? I hope the cylinder head doesn't need to come off? Or can it be extracted being undoing the top engine mount and moving the engine forward and right as much as possible?
Posted 25th May 2016 at 08:30
was it a new mc? still got a load compensator?
Posted 25th May 2016 at 08:33
ben tearle
No a used one, yes it still has the rear load compensator fitted.
Posted 25th May 2016 at 09:18
get a new mc and check the compensator isnt seized
Posted 25th May 2016 at 10:04
ben tearle
Ok cheers will do - the compensator arm appears to move.
Posted 25th May 2016 at 11:04
fatlapit
Bin the compensator and fir a bias valve
Posted 25th May 2016 at 11:38
ben tearle
Would that not be an MOT failure then though?
ECP and GSF don't seem to stock a new 23.8mm 2 port master cylinder, I'll have to keep hunting, or get a rebuild kit
Posted 25th May 2016 at 11:51
fatlapit
nope
Posted 25th May 2016 at 12:17
Ignore the servo to begin with.... pump the pedal till hard (no servo assistance) then hold it down hard.... if it still sinks then slowly your fault is with the master cylinder or possibly the compensator leaking internally.
If the pedal stays rock hard and doesn't sink then the master should be ok and I'd try a new compensator / fit bias valve as said then swap the servo.
Posted 25th May 2016 at 22:58
Tend to have issues with master cylinders over servos. Especially if they have been sat a while.
Posted 25th May 2016 at 23:26
Also the servo is a bas**rd to change. Only a couple of hours but all awkward. Did one on Aaron6's Mrs 306 hdi a while ago.
Posted 26th May 2016 at 07:45
