Author Subject: Oil leaks
deeturbo
Hi all,
I'm going to be doing a fair bit of work on my car in the coming weeks and I was wondering where the common places these engine leak oil from?
I'll be replacing the cam seals and OS crank seal when replacing the cam belt and I'll be replacing the NS crank oil seal when replace the clutch with the gearbox seals (input shaft, and drive shaft seals).
Is there any other seals I should get before commencing work?
There seems to be a drip of oil from the power steering pipe that runs under the car are these normally a weak spot?
Posted 21st May 2016 at 14:36
fatlapit
Cam covers are a prime suspect
Posted 21st May 2016 at 16:33
deeturbo
I think the previous owner said that he replaced the cam cover gasket so hopefully that should be good but I'll check it, thanks.
Posted 21st May 2016 at 17:36
cully
main bearing cap side rubber seals behind the flywheel seap after time
Posted 21st May 2016 at 17:44
deeturbo
Ooh, I didn't even think of those.
Doesn't the sump have to come off to change them?
Posted 21st May 2016 at 18:59
cully
yes
Posted 21st May 2016 at 19:09
deeturbo
How much of a pain are they to change and is it easy to get wrong and cause a leak?
Posted 21st May 2016 at 19:56
cully
a pain yes but it is doable
maybe wait till the clutch is being done as you will disturb the crank seal behind the flywheel too
Posted 21st May 2016 at 20:22
deeturbo
Planning on doing the clutch this weekend with the crank oil seal and "hockey stick" seals.
What RTV sealant would you guys recommend on refitting the sump?
Posted 5th Jul 2016 at 12:37
cully
Posted 5th Jul 2016 at 13:11
