Author Subject: Should this be connected? Power steering
sergioiacobucci
Noticed this last night:
Does this need to be connected?
Phase 1 silver track car
335i daily
Posted 20th May 2016 at 11:43
cully
power steering pressure switch
i think it changes the rpm at idle when/not under load from steering
Posted 20th May 2016 at 11:46
sergioiacobucci
So increases rpm when under load to compensate and keep it idling the same? Should I connect it?
EDIT: My question is more along the lines of, why would someone disconnect it?
335i daily
Posted 20th May 2016 at 12:04
sergioiacobucci
Being lazy on my mobile found the answer
Rich E wrote:
It can cause erratic idle problems as the sensor is used by the ECU to lift the revs if the power steering is under load at low revs to stop the engine stalling under the extra load the PAS pump needs.
I would recommend replacing it. Even if it appears to be okay without it you'll always be left with a question mark over it if you have any issues in the future.
Will probably replace it
335i daily
Posted 20th May 2016 at 12:13
Yup can cause stalling issues or revving up issues. May be nothing wrong with it and was something else.
Posted 20th May 2016 at 13:34
sergioiacobucci
True I will plug it back in and see how it reacts. Can't imagine replacing it will be too expensive or difficult of I need to.
335i daily
Posted 20th May 2016 at 14:27
