Author Subject: Radiator leaking bottom hose
sergioiacobucci
Still need to finish off the engine mount however I have a leak from the bottom hose at the moment.
The radiator was sitting poorly as the mount on one side is missing. I have tried some searching but couldn't seem to find an image of this area.
I am not sure what the connection on this hose is supposed to look like so I have attached some images:
[/URL]
[/URL]
[/URL]
Could someone let me know if this looks like it's hanging off? Its not leaking like crazy however it's quite annoying having to keep topping up! Thanks
Phase 1 silver track car
335i daily
Posted 8th May 2016 at 17:19
It's looking a bit knackered. Yes
You have the early type hose fitting there, the later style is much better although it requires the rad to be changed to allow the later pipe designed to be fitted.
New pipe time.
Posted 8th May 2016 at 18:22
sergioiacobucci
New pipe time.
Thanks, so you think I should order a new one or try refitting this one? What this connector called so I can order a new one if I need to?
335i daily
Posted 8th May 2016 at 20:07
It's just the lower rad hose that you need a new one of.
Best to buy new - I think you'll always have problems if you try and patch that up.
Just remember that you need an earlier style hose (which the chassis number should show anyway).
If you get given a hose with a triangular shape metal clip at the rad end it's the later one and won't fit.
Cheers.
Posted 8th May 2016 at 22:52
sergioiacobucci
Cheers.
Thanks. Did some research looks like this is the part number 1351X9 - however looks like I can only order this from Germany which seems odd, there are probably multiple part numbers
335i daily
Posted 8th May 2016 at 23:41
hose looks fine, you can replace the o ring.
Posted 9th May 2016 at 08:28
sergioiacobucci
Thanks I'll search around for the part number
335i daily
Posted 9th May 2016 at 09:09
use the link in my signature.
1339 94
O-RING
DIAM INT 31 EP 3,6
Posted 9th May 2016 at 11:41
sergioiacobucci
1339 94
O-RING
DIAM INT 31 EP 3,6
Thanks mate
335i daily
Posted 9th May 2016 at 12:16
