Author Subject: Trailing arm
Anyone got a spare trailing arm going spare?
I'm not bothered at all about the calliper or disc, or trailing arm shaft being there, just the arm and bearing assembly, the bearing doesnt even have to be in great condition. Either side will do.
So, if anyone has this, how much delivered?
Posted 2nd May 2016 at 15:07
Which side you after?
I have a beam off my old 6 but the Xsara one thats currently on had snapped nuts where the Disc shield should mount! (that's NS) so might use the arm off my old beam if i cant get the old threads out or Tap!
I'm only in Leeds so could collect?
Posted 2nd May 2016 at 15:56
It doesnt matter which side for me.
Do you mean you might mis-match a gti6 and xsara arm on one beam? I'd be careful if that is your intention as i think the xsaras have more toe so mixing would cause some funky handling.
Yeah collection would be possible if you do end up with a spare unwanted arm. Obviously i'll give you some beer tokens for it Thumbs up
Posted 2nd May 2016 at 16:56
I had no idea they had different Arms!
I know the Torsion bars were bigger and the Xsara one was seen as an upgrade over the standard one I can tell you it's a lot bloody heavier that's for sure! i'll see if I can get one pulled off!
Posted 2nd May 2016 at 22:08
Nice one, just let me know the outcome Thumbs up
Posted 3rd May 2016 at 19:10
fatlapit
Steve i got one.
What do u want with it??
Posted 8th May 2016 at 10:22
I was thinking of stripping one down mainly to see how the bearing assembly all goes together then decide whether i should go to the effort of attempting to improve or make a fresh rear axle for the track car.
How much would you want for it Chris?
Posted 8th May 2016 at 21:46
fatlapit
Ill bring it to fcs bud u can have it
Posted 8th May 2016 at 22:24
Thanks Chris! Thumbs up
I won't be at FCS, will you be at Pugfest?
Posted 9th May 2016 at 22:31
fatlapit
No bud. Hmmmm unless i come up the a1 on the sunday sfter fcs
Posted 9th May 2016 at 22:34
It's up to you mate, i don't want to be a burden for you though.
Posted 10th May 2016 at 17:07
fatlapit
I can do bud its not a problem
Posted 11th May 2016 at 18:43
