Author Subject: Heater always hot
heliosphan
I've what sounds like the same issue as Chris, here:
http://www.306gti6.com/forum/showthread.php?id=141610
Can anyone tell me if this is the little motor that controls the flap to direct air through the heater assembly?
I'm refering to the object in the upper centre of this picture:
Those photos were taken from the passenger side, looking towards the centre console from the footwell, under the dashboard.
Posted 4th Apr 2016 at 11:31
heliosphan
To continue this busy thread, I've discovered that the temperature control is intermittent. Sometimes I'm able to control the temperature effectively and other times it only blows hot. It seems that it changes with the engine being turned on and off.
This suggests to me that the heater control unit or the flap motor are being 'shocked'/'reset' into life sometimes when I start the car. Increased likelihood of the heater control unit maybe? I guess I'll monitor it and test its operation in differing scenarios to rule out causes.
Posted 10th Apr 2016 at 22:16
Probably the main heater control panel relay being a bit sticky, the one tgat often melts its holder in the fusebox.
Posted 10th Apr 2016 at 22:37
heliosphan
Meirion, thank you for joining the party. Is that relay in the cabin fuse box or the engine bay? I'll check for melty s**t on the holder ASAP.
Posted 10th Apr 2016 at 22:56
in the cabin, i don't recall which it is, green i think.
Posted 10th Apr 2016 at 23:22
alcon
I can confirm it's green and inside the cabin fuse box as mine melted recently. They can be difficult to pull out when they do this.
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 11th Apr 2016 at 07:54
yep. had this on every 306 i've had. maybe i'm just lucky
Posted 11th Apr 2016 at 08:43
