Author Subject: ATB LSD
cully
can the STD diff be replaced with the quaife while the gearbox is in the car?
if so anything to watch for/replace while in there
Posted 1st Apr 2016 at 19:51
its possible but a right bloody faff, ve done it in a 205 with an ap suretrac, it varies whether the casings needs relieving to clear the diff also.
Posted 1st Apr 2016 at 19:58
Be easier just to whip the box off bud
Posted 1st Apr 2016 at 21:15
fatlapit
Quafie drops straight in no mods to the casing needed
Posted 1st Apr 2016 at 22:30
superchargedblack1997gti6
Yep can be done in place not too bad!
Posted 1st Apr 2016 at 23:19
If you remove the subframe loads of room
Posted 2nd Apr 2016 at 20:57
I did my 3j with the box in place & even filed the casing down in place & a ATBs easier ...but removed my subframe
Posted 2nd Apr 2016 at 22:08
cully
hmm remove the subframe you say....... might seam weld up one i have laying around and give it a lick of paint Wink
Posted 2nd Apr 2016 at 22:39
They do in some boxes, you've been lucky Thumbs up
Posted 3rd Apr 2016 at 09:37
Mine was fine didn't even think about it tbh I thought quaife ones were all meant to fit without hacking at the casing but plate diffs need some removed. Mine turned over fine soon as it was fitted no clearance issues at all.
Posted 5th Apr 2016 at 23:10
fatlapit
The amount of boxes ive been though. Theres loads of room
Posted 4th Apr 2016 at 23:17
Ive fitted a 3j into a few casings as well as a quaife, varies a lot, mainly the older casings that need work iirc, both will need work in some but none in others
Posted 4th Apr 2016 at 23:56
cully
what work is needed if any?
i guess its jut rotate diff see if catches box or casing remove/grind back tight spot
Posted 5th Apr 2016 at 06:10
Pretty much this. Yes
Posted 5th Apr 2016 at 07:24
