Or should I just fold it back gently with a hammer.
| Author | Subject: Front wheel arch |
RallyeP6
Regular Location: West Byfleet Registered: 11 Jul 2013 Posts: 451 Status: Offline |
superchargedblack1997gti6
Cut it back to where it needs to be and and then re weld it mate?________________________________________ Super high boost Completed, destroyer of gearboxes and 160mph club |
RallyeP6
Ahh, I thought that might be the case, didn't really want to take it somewhere to have it welded, as I don't know anywhere around here.Will remove the sealant and paint and see where the spot welds are, and try and cut it back just enough if possible. Thanks Ross, oh and nearly finished the bumper too, took a lot looonger than I thought. |
move the wheel forwards.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RallyeP6
Yes I know that is the proper way to do it, adjustable wishbones etc etc, lots of money and more money. |
you're the one that chose to use wheels too big, now see the consequences ![]() do it right or go home ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RallyeP6
I know I know, I will ruin the ride and handling and comfort just for the sake of the cars looks. |
Lol what size wheels have you gone for then 18"? I've seen a.few 306's sit closer than that on 15's in my time.... due to being crashed and bent wishbones lol. ________________________________________ Black power baby! SUUUUUPERCHARGED Seat Leon FR TDI 190BHP 300lbft daily gti-6 killer :p 12x 306's owned so far Cambelts, clutches, service work carried out on All makes and models, Peugeot Citroen / mitsubishi specialist. Pug planet / Citroen Lexia diagnostics / code reads available. |
they weren't even that close when my ZX was sitting on 195 65s, which are huge balloons!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RallyeP6
Tyres are 225 45 17, strange thing is the nearside wheel rubs more when turning more than the off side, is that something to do with rack and 6 speed box combination?.Anyway, got new wishbones and ball joints from Febi, going to make little balljoint extensions which will space the wheel out by 30mm and move the balljoint further forward by 30mm. Have found that Citroen C5 drive shafts are about 30mm longer than 306 ones, so will order a pair of those. Just need to extend the track rod somehow. Contemplating buying a little bandsaw or just use the jigsaw to cut the 6mm plate steel for the extensions. |
not surprised they rub thenwelshpug! has attached the following image: ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
derp, thought you said 18".something wrong if its 17" though will only be 12.5mm less. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RallyeP6
I used the same website to check tyre diameters before buying the tyres. |
