Just looking for the best way to go about fitting the door and making sure it aligns the same as the old one?
98 Blaze 6 - Current
| Author | Subject: Fitting Drivers Door |
oliverharveyuk@hotmail.co.uk
Regular Location: Banbury Registered: 16 Feb 2016 Posts: 231 Status: Offline |
I am getting a replacement drivers door this weekend as my current one has a couple of nasty dents.Just looking for the best way to go about fitting the door and making sure it aligns the same as the old one? ________________________________________ 98 Blaze 6 - Current |
remove the hinge pivot bolt rather than the hinge from the door, it'll be much closer then to start with.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Seasoned Pro Location: Southwark Registered: 18 Jul 2010 Posts: 4,865 Status: Offline |
The way I have done is like follows:Get one (hopefully two helpers) Sit in the drivers seat, get them to hold some of the weight of the door, Unscrew doors from body (ideally mark around the brackets with tippex) Then get them to bring the door to you and line it up, Get it as close to as it was as possible then do it up fairly loosely and gently close the door to see how it lines up. You can make quite a bit of adjustment by slackening off the mountings and then rotating up down/pushing or pulling away form body. Its basically trail and error, Once it's right, Tighten up all the way. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
welshpug! wrote: remove the hinge pivot bolt rather than the hinge from the door, it'll be much closer then to start with. Or that. Which is probably easier. ________________________________________ Ex- Phase 3 China GTi-6 T-Reg |
When you say hinge pivot bolt you mean this:oliverharveyuk@hotmail.co.uk has attached the following image: ________________________________________ 98 Blaze 6 - Current |
yup.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Thanks I'll let you know how I get on. So glad I joined this forum full of wisdom!!!________________________________________ 98 Blaze 6 - Current |
rikky
oliverharveyuk@hotmail.co.uk wrote: Thanks I'll let you know how I get on. So glad I joined this forum full of weirdos!!! ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
cully
Seasoned Pro Location: Cullompton Registered: 12 Jun 2013 Posts: 1,093 Status: Offline |
if you undo the pivot bolt the door will not fall off, as the lower hinge is cone shaped into the top hinge part |
Seasoned Pro Location: Skelmersdale Registered: 07 Apr 2004 Posts: 2,769 Status: Offline |
I got a new pair for mine and did it on my own by undoing the hinge pin bolt.The hardest part turned out to be reconnecting the door loom connector. ________________________________________ S Reg Diablo standardsSpec SORNEDR Reg Nile standard spec written off then repaired X Reg Astor in need of TLC R Reg Nile to restore Set of Lions to fit. |
