Author Subject: faster ! faster!
potpot
Thinking of going down the root of throttle bodies and would like some advice guys please. I'd like to know exactly whats involved, what bits or setup id need and what kind of cost im looking at. My rallye's current set up includes newman 285 cams, all the additional rebored block with forged 86.5mm pistons to match.
Few other bits such as lighten n balanced flywheel, remapped, aftermarket exhaust, KnN etc.
Posted 29th Mar 2016 at 20:07
this is my setup with prices from memory -
satchell inlet £180
jenvey 45's with pq2 lever £380 for 118mm bodies, £420 for 92mm
home made cable bracket
shortened standard throttle cable
trumpets £90
backplate free from a mate, would cost £25 I think
itg filter £25 - used, £90 ish.
original fuel rail fpr and injectors. serviced.
jenvey fuel rail £62
clio iwp042's. used, serviced.
dta s40 ebay us £400, rrp £550
home made wiring loom £70, components and wire from harnessing solutions
aem wideband lambda £100 used, rrp £150
torques fuel lines and fittings £100
mapped by sandy brown £300
mef motorsport can help you with the jenvey and dta bits, and the loom if you don't fancy making it yourself.
Posted 29th Mar 2016 at 20:45
potpot
satchell inlet £180
trumpets £90
So a fortune then Whistle
Posted 29th Mar 2016 at 20:55
RallyeP6
Can be a fortune or if you are fortunate like me, I bought my Jenvey 45mm and fuel rail, injectors, linkages, Longman manifold etc for only £400. Already had my DTA, made my loom, the only one big expense was the mapping.
It can be done on the cheap but may take time to wait for the bits to come up for sale.
Worth it in the end though, the sound of 4 wide open throttle butterflies on the rolling road is awsome!.
Looks like you already have a head start with the engine mods though.
Posted 29th Mar 2016 at 21:08
potpot
What powers gains did you see ?
Posted 29th Mar 2016 at 21:21
potpot
Ive noticed pug 1off does some kits ?
Posted 29th Mar 2016 at 21:23
RallyeP6
Not much, 183 bhp on the rolling road, with standard everything else, I put a limit of 6000 RPM as the engine had done 100K miles, though the head was rebuilt.
Posted 29th Mar 2016 at 22:21
I wouldn't go with a kit, you wont get a satchell inlet in one Wink and they usually include a linkage kit which is £80 you dont need to spend, have a look in my project thread for more details and pics.
6k limit?! mine went to 7700! stock engines peak at 6500, a bit more on bodies, not sure where my peak was but on ph2's it was roughly 200 bhp flywheel at standard 86x86.
100k miles is nothing!
Posted 29th Mar 2016 at 22:47
What's the power and torque like on your ph4's potpot?
Posted 29th Mar 2016 at 22:49
potpot
I seem to of lost the relevant paperwork but 196bhp rings a bell, not sure if thats flywheel or wheels of course, i know the cams and other relevant work should compliment throttle bodies nicely.
Posted 30th Mar 2016 at 18:47
6k limit?
WHATTT
I take my 138ish k miler to 7000 often. Still has all the horses in the stable.
Maintenence is the key
Posted 11th Apr 2016 at 10:53
eliotrw wrote:
6k limit?
WHATTT
Swapped out my engine 4 years ago for a low mileage one and fully rebuilt the head but it occasionally catches the limiter at 7650rpm in first if you don't change up as the rev counter gets to 7k because the needle can't keep up with the engine speed lol.
Good maintainance inc good quality belt and pump and you won't have a problem. These heads have double valve springs for a reason.
Posted 11th Apr 2016 at 11:19
RallyeP6
I do have history with the car, and the head was rebuilt, just played it safe for everyday road use.
Posted 11th Apr 2016 at 12:49
fatlapit
potpot ure a local lad I see
Posted 11th Apr 2016 at 13:07
potpot
Ish mate ish, bout an hour or so away.
Posted 11th Apr 2016 at 18:28
aaron6
armzsc6 wrote:
eliotrw wrote:
6k limit?
WHATTT
Mines got 162k miles on it and I never think twice about taking it up to 7k revs. Get that limiter raised. A lot!
Posted 11th Apr 2016 at 18:50
