Author Subject: ECU/immobiliser fault
Andy.C
hi all,
if anyone could please help with this it would be much appreciated.
basically the thing won't start, i think its something to do with the immobiliser or ECU but I'm not sure. the cars been sat for a while (couple of months maybe) i removed the battery to charge it up, i put the battery back in and she fired up no problem but then when i tried again she won't fire.
now the little red LED above the radio no longer flashes, central locking doesn't work either. few things on the dash like the mileage doesn't show, stop light is on etc. anyway I've put a link to a video so you can see whats going on.
not sure if this is worth mentioning just to eliminate, the crank sensor is new, the fob has had a new battery just incase,
Thanks Andy
ps im not sure if this has been covered before sorry in advance
https://youtu.be/4Lt_rWhiNRM
Posted 27th Mar 2016 at 14:55
cully
check the fuses in the fuse board there is one that feeds the immo/alarm charging circuit Wink
Posted 27th Mar 2016 at 15:07
Andy.C
thanks for relpying
any idea witch fuse, I've had a look at the fuse diagram in the FAQ but cat see owt for immobiliser or owt like that. phase 3 by the way
Thanks
Posted 27th Mar 2016 at 15:13
Andy.C
Number 6 fuse can't believe it was just that little 5 amp fuse thanks for pointing me in the right direction
Posted 27th Mar 2016 at 16:18
cully
no problem Wink
Posted 27th Mar 2016 at 16:38
sageman
better off than me the local garage charged me £50 to replace that fuse
w**kers
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 27th Mar 2016 at 18:44
See you got your £5 membership back & saved £45 LOL
Glad it's sorted Thumbs up
Posted 27th Mar 2016 at 19:03
