| Author | Subject: Fuel tank breather |
RallyeP6
Regular Location: West Byfleet Registered: 11 Jul 2013 Posts: 451 Status: Offline |
Does anyone have a diagram or know of where I can look on the web, of the layout of the fuel system. I want to know how that canister under the offside wheel arch is connected up in the system and the brown solenoid valve on the inner wing. As I have throttle bodies and another ECU now, it is disconnected, just wondered if I can remove all those parts and another container that is on the offside rear wing by the fuel filler hose. |
servicebox has diagrams, yes you can remove it back to the tank and add a one way rollover valve.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
RallyeP6
Signed up, logged in, see it, thanks Welshpug. |
I'm running Jenveys & 8 injectors with two fuel rails ...I've just taken everything inc pipe work off back to the tank & fitted a one way roll over valve under the rear wheel arch ..it has to be upright ..used the pipework under the car back under the drivers rear wheel arch ... Also removed all my fuel plastic pipes under my car at the same time ... Take your drivers wing off & all will become obvious m8 Some pics are on my project thread |
ravemercer
Regular Location: kent Registered: 18 Jan 2009 Posts: 422 Status: Offline |
Got a link to the valve your purchased did you fit to the original vent pipe ? |
ravemercer wrote: Got a link to the valve your purchased did you fit to the original vent pipe ? I used this on a p clip ...fitted upright under rear drivers arch liner ...plus used all the old plastic pipe that pushed on & fuel line clipped it but rerouted it to the arch liner & didn't remove the tank . |
Sorry this forgot ..https://www.merlinmotorsport.co.uk/p/roll-over-valve-in-line-with-1-4-6mm-push-on-tails-m-trl7 |
blandy
Do you leave the top open on the valve or do you run pipework on top. Got rid off all mine today now just left with the small black hose now |
quote: [quote="blandy"]Do you leave the top open on the valve or do you run pipework on top. Got rid off all mine today now just left with the small black hose now Ran mine up into the Filler cap flap ...been told people run there’s into the boot and down into the corner of the boot below the inside of the lights pass one way flaps to out side |
