Author Subject: Drivers window not going up
alcon
Drivers window not working but passengers side is. Is this likely to be the switch or the wiring?
1999 GTi-6 (china blue)
1999 Rallye (black)
Posted 28th Feb 2016 at 17:39
Wiring in door opening loom ...I recon thick white wire m8.Thumbs up
Posted 28th Feb 2016 at 17:51
alcon
Thanks. Going to check it tonight. Is the white wire you're talking about inside the drivers door? I presume I'll need to take the door card off to get into it
1999 Rallye (black)
Posted 28th Feb 2016 at 18:04
No it's in side the rubber you can see when you open the door ...common problem they break with the years of door opening and closing Thumbs up
Look in FAQ for info on how to fix m8
Posted 28th Feb 2016 at 18:31
scotzman
Is the passenger side working from the driver side main switch? If so I would say the switch or the regulator.
Posted 28th Feb 2016 at 18:37
alcon
Yes the passengers side window is working from the drivers side switch.
1999 Rallye (black)
Posted 28th Feb 2016 at 18:53
alcon
Window has just gone back up so I'm guessing it might be a faulty or loose wire....or perhaps an intermittent fault in the switch. Too cold to work on it tonight in the dark so won't be putting my windows down until I can get it fixed probably!
1999 Rallye (black)
Posted 28th Feb 2016 at 20:57
cully
as said broken loom wire in the door jam, try opening and closing the door while the switch is pushed see if it cuts out in on the windows
Posted 28th Feb 2016 at 21:08
alcon
Will try that tomorrow....just a little wary of putting window down now in case it doesn't go back up!
1999 Rallye (black)
Posted 28th Feb 2016 at 21:45
