Author Subject: side airbag light on and differant timeing to it going on
sageman
(ph 3)
well my side airbag light is on and upon playing with the cables under the seats ive found something out
passenger side: unless the pre-tentioner has been unplugged the light comes on with the ignition goes out then comes back on after 10 seconds by my count
drivers side if the yellow plug is unplugged it is again 10 seconds but if the red plug is also unplugged or if just the red is unplugged it goes down to 5 seconds
is this something that is known about and does anyone know what the differant timeings mean on a correctly working car
1976 Reliant Kitten
1985 Reliant Fox Tandy campervan
1998 GTI-6
1993 Citroen XM sei V6 (barn find)
Posted 28th Feb 2016 at 19:24
sageman
now im very confused
the garage said that the only thing that came up was 165 ignition pretentioner 2
but on unplugging the orange plug drivers side or passenger side the airbag light comes on too as well as the side airbag light so the plugs cant be the issue and surly side airbag light would mean an issue with just the side airbags not the pretentioner
1976 Reliant Kitten
1998 GTI-6
Posted 5th Mar 2016 at 11:40
cully
ignition pretentioner..............
try the side bag sensor on the sil
there are two one each side bolted to the sill near the filler cap release and same point passenger side
Posted 5th Mar 2016 at 12:17
sageman
i bet theyre inside the plastic trim things aint they
1976 Reliant Kitten
1998 GTI-6
Posted 5th Mar 2016 at 14:33
cully
the carpet and underlay cover them
Posted 5th Mar 2016 at 15:40
sageman
oh do they good
just need for it to stop raining again now
1976 Reliant Kitten
1998 GTI-6
Posted 5th Mar 2016 at 16:15
cully
yes inside the car not outside Wink
Posted 5th Mar 2016 at 18:49
sageman
well i had a look at them they were both plugged in but i stuck a safety pin down inside the contacts to clean them
now instead of the side airbag light going off then on again it just comes on and stays on
1976 Reliant Kitten
1998 GTI-6
Posted 8th Mar 2016 at 22:14
sageman
hmmm thinking about it im not sure i plugged the drivers side back in i dont remember doing so
1976 Reliant Kitten
1998 GTI-6
Posted 9th Mar 2016 at 09:14
sageman
well today i did everything i could think of
under the seats has been re-done with bullet connectors and cant be the side impact sensors as when theyre disconnected the side airbag light doesent go out then come back on just stays on all the time
1976 Reliant Kitten
1998 GTI-6
Posted 23rd Mar 2016 at 16:56
