Author Subject: Clutch arm too high?
justsamo
Hello all,
Still slowly plodding through a clutch change..
Whilst putting the new bushes and things in,
once I'd put the clutch arm back on top of the fork and put the pin in, it looks about an inch higher than the rest of the clutch cable brackets?
Box isn't back on yet but am I going crazy here or is something not right? Looks as if there would be a massive kink in the clutch cable....
Posted 14th Feb 2016 at 22:07
arm could be bent, check the clutch fork fingers are equidistant over the input shaft.
Posted 14th Feb 2016 at 22:32
justsamo
Nope everything looks fine! It couldn't go any further into the box and the pin lines up as it should...
Posted 14th Feb 2016 at 22:58
A picture may help ....Thumbs up
Posted 15th Feb 2016 at 08:43
It's bent then. Bend it back.
Posted 15th Feb 2016 at 10:00
Is this what happens when people don't take the pin out & bend the arm to remove the box ?
Posted 15th Feb 2016 at 13:16
yup.
Posted 15th Feb 2016 at 13:20
You can't always get the pin out
Posted 15th Feb 2016 at 17:39
justsamo
It's a brand new arm... Granted I bent the other one. Smile so I don't understand, but like a comment said, once I can get a picture I'll upload it. Thanks again guys.
Posted 15th Feb 2016 at 19:30
You 100% sure it's the correct arm ?
Posted 15th Feb 2016 at 19:44
