Author Subject: Pics of 6/Rallye without front wings....
Ben_W
Formerly gpm
Anyone got any pics of a 306 without any front wings on?
I need to see what's accessible without them pls.....
Posted 14th Feb 2016 at 18:54
marksorrento205
I have a 306 without wings on it. Any area in particular you are after?
Posted 14th Feb 2016 at 19:03
cully
any good??
Posted 14th Feb 2016 at 19:08
Ben_W
Formerly gpm
That's bang on thanks Cully.
As soon as the weather is better, I'll be continuing the resto on the rallye. The front arches have had the same nasty, sticky black underseal stuff applied which needs to come off. Blasting it off isn't an option as I think the blast media will just stick to it.
I was just looking at things from an access point of view. I think that should give me all the access I need.....I hope! Plan is to finish stripping the engine bay down, get rid of the underseal from the arches then send it off to have the front end and engine bay blasted. Then it will be the same as the undersides had.....zinc primed, Epoxy masticed, seal sealed then off for paint.
Posted 14th Feb 2016 at 19:15
cully
Posted 14th Feb 2016 at 19:21
Do the wings come off easily without cracking the side sills?
Posted 15th Feb 2016 at 00:53
if you're careful yes they come off easily. never cracked a sideskirt getting the wings out
Posted 15th Feb 2016 at 08:09
cully
yes they come off with the side sills attached you will have to remove 2 or 3 rivets that fix them to give you a little flex though.....dont do it on a cold day or you will probably crack the plastic sill trim
Posted 15th Feb 2016 at 08:29
