Author Subject: Best Earth points
bak
What are the best earth points when you put the battery to the boot or behind the passenger seat? I have used the forum search but usually appear "Sorry, you do not have access to this thread"
Could you help me with any information o pics? Thank youThumbs up
Posted 12th Feb 2016 at 23:02
cully
drill a hole in the metal clean the paint and bolt it down to a solid welded panel not a riveted one
Posted 13th Feb 2016 at 09:31
bak
Thank you mate
Do you think the best place is where the co-driver seat is bolted on the door side or better where the rearseat belt are bolted on?
Is it enough two points or is it better more than two?
Posted 13th Feb 2016 at 11:06
cully
one dedicated bolt point will work, dont share it with any other fixing as they will work loose with movement
Posted 13th Feb 2016 at 11:46
bak
Ok I will try it this afternoon Wink
Posted 13th Feb 2016 at 13:26
Any of the rear seat belt mounting points would do
Posted 13th Feb 2016 at 13:48
