Author Subject: Cat cams valve clearance
mrtickle
Is it possible to measures the cylinder head thickness without removing it . Got some cams just want to check before fitting them .
Posted 28th Nov 2015 at 20:13
Which cams?
Posted 28th Nov 2015 at 20:26
Moved to Engines. Smile
Posted 29th Nov 2015 at 00:30
mrtickle
Which cams?
I'm unsure will check tomorrow on the cams , I have had the head skimmed once but I'm not certain how much was taken off it was 5 years ago and believe this is the only time it has been skimmed.
Posted 29th Nov 2015 at 22:10
mrtickle
Which cams?
The cams that I have are -4903109- cat cams any advice would be great.
Posted 3rd Dec 2015 at 17:09
http://www.catcams.co.uk/acatalog/4903109.pdf
Posted 3rd Dec 2015 at 17:56
2mm lift at tdc on inlet, 1.4 exhaust, too much for std pistons even machined, borderline too much lift for std valves also.
Posted 3rd Dec 2015 at 18:02
mrtickle
Aw ok what if I had a thicker head gasket and machined Pistons would that still not work .
Posted 3rd Dec 2015 at 18:18
wilder cams need more compression not less, you would lose a fair bit if you put a gasket thick enough to get safe clearance, I don't think you'll find a gasket thick enough for that as well
Posted 3rd Dec 2015 at 20:30
mrtickle
Ok that's a pain never mind thanks anyway Thumbs up
Posted 3rd Dec 2015 at 20:59
pete_rallye
Explain please?! You mean valve to valve clearance?
Lap of the 'ring
Posted 3rd Dec 2015 at 21:13
no, risk of going coil bound, mssed the 'spring' word out!
Posted 3rd Dec 2015 at 22:03
pete_rallye
Ah ok, do you know what height the standard springs go coil bound at?
Lap of the 'ring
Posted 3rd Dec 2015 at 22:31
I can't remember the exact figure, but its around 10.9, they'll hit the spray bars past 10.9 also if they're the same base circle as a standard cam.
Posted 4th Dec 2015 at 11:06
