Author Subject: Compression Test
djb
As a follow up to the pressure when cold thread, I had a compression test done.
Starting from the cylinder closest to the cam belt:
210 psi
210 psi
201psi
216psi
Do these sound ok?
Posted 26th Nov 2015 at 01:09
Yeah, they are absolutely fine.
However, on these engines quite often a compression test doesn't show up a failing head gasket as they tend to go on the edge of the water jacket as opposed to between cylinders, unless they fail completely.
Try running the engine with the rad cap off and see if there are any bubbles in the coolant. Alternatively, get a sniff test done.
Posted 26th Nov 2015 at 07:36
djb
Sniff test passed !! What a relief!!
Thanks for your input Stan
Posted 27th Nov 2015 at 05:57
Sounds like it's all good then, glad to hear. Thumbs up
Posted 28th Nov 2015 at 01:56
