Author Subject: Engine loom diogram
eddy_gti6
Anyone got an engine loom diogram for a phase 2/3 gti6? Can't seem to find one in my Haynes manual
Posted 20th Nov 2015 at 10:06
cully
i can get the layout diagram later once home Wink
Posted 20th Nov 2015 at 13:01
eddy_gti6
Al drop you a pm mate
Posted 20th Nov 2015 at 13:45
its on the 205 forum
Posted 20th Nov 2015 at 14:14
eddy_gti6
Got a link? I'm not a member on there
Posted 20th Nov 2015 at 14:19
eddy_gti6
ah just found it, thanks mei
Posted 20th Nov 2015 at 14:28
cully
gti6 ph2 engine loom layout wiring diagram RPO 7530 (1998)
1020 : alternator /
1115 : cylinder reference sensor /
1120 : knock sensor /
1131 : cylinder 1 ignition coil
1132 : cylinder 2 ignition coil
1133 : cylinder 3 ignition coil
1134 : cylinder 4 ignition coil
1203 : inertia switch /
1215 : purge canister solenoid valve
1220 : engine coolant temperature sensor
1226 : idle regulation motor and idle switch
1240 : induction air temperature sensor
1270 : carburettor or throttle housing heater resistor
1273 : oil breather re-heat resistor 1
1304 : engine management multi-function double relay
1305 : richness potentiometer
1312 : induction air pressure sensor
1313 : engine speed sensor
1320 : engine management control unit
1331 : injector cylinder no.1
1332 : injector cylinder no.2
1333 : injector cylinder no.3
1334 : injector cylinder no.4
1350 : upstream oxygen sensor /
1620 : vehicle speed sensor /
4105 : engine oil pressure indicator
4120 : engine oil level sensor
7001 : power steering fluid pressure switch
8020 : air conditioning compressor
IC02A : main harness interconnection with engine harness (A)
IC02B : main harness interconnection with engine harness (Cool
EB10 : crimp d 1 + battery protected by a fuse no. 10
ECC1A :
MM01 : point de masse moteur numéro 01
EM01A : crimp earth (earth point number 01A)
EM03 : crimp earth (earth point number 03)
E101 : crimp one information (or equipotential 101) wire
E121 : crimp one information (or equipotential 121) wire
E126 : crimp one information (or equipotential 126) wire
E134 : crimp one information (or equipotential 134) wire
Posted 20th Nov 2015 at 22:18
