Author Subject: 2.2ltr engine posibilitys?
cully
ive not found anything much on this conversion
looking for pros and cons is it a viable quest?
gti6 Block 86mm bore decked for correct compression
gti6 head
DW12TED4 crank 96mm stroke 60mm mains 50mm big-ends
S16 rods and pistons 152mm rod length 50mm big ends
what are the disadvantages of the Under-square engine compared to the square stroke of the STD Gti6
Posted 27th Oct 2015 at 17:23
aaron6
Dunno mate. But there's a big thread on a 2.1 build.
Posted 27th Oct 2015 at 17:30
eddy_gti6
Dont think you will get away with running S16 rods and pistons with a 96mm crank as you run them with an 88mm crank to get just under a 2.1 if i remember right.
Pretty sure it was matty_rallye on here used a 92mm crank out of a 2.1 xu 406 and 87mm pistons and custom rods
cully
CC=pi × r² × h × 4
std gti6 = 1999.0 = pi × 43² × 86 × 4
DW12 crank = 2231.4 = pi × 43² × 96 × 4
Posted 27th Oct 2015 at 17:44
cully
what are the limits of the S16 rods?
Posted 27th Oct 2015 at 17:45
xud11 92mm crank and 87mm bore is a good combination, you will need custom rods and pistons to make it work and last.
s16 rods and pistons will do a 2044 cc on an 88 mm crank, main issue is the wear of most iron blocks and finding good s16 pistons, they're not the lightest of alloy lumps either!
the main issue with the s16 rod is that theyre quite short, giving greater thrust angles at mid stroke, ots better to go longer rod shorter piston.
most standard rods will be fine for mild hydraulic builds, once you get into the higher rpm solid tappet builds do you need to make sure you have good geometry, you would usually be on lighter pistons by this point anyway so can take them further without issue.
Posted 27th Oct 2015 at 18:33
cully
custom rods and pistons will add many ££ to a build i may as well buy a second hand SC kit Wink
how do the S16 pistons wear i guess the piston skirts get worn ?
ive yet to get the pistons and rods out my S16 block nearly there bloody clock changes slow things down
Posted 27th Oct 2015 at 19:01
sc is boring and troublesome, think of the trumpets!
pistons wear through use, furthest you can take the s16 ones is 88mm crank as they sit 1mm below deck on 86mm, but compression needs checking as itll change a decent amount from the 10.8 std gti6 with the increased capacity and smaller compression height volume of the s16 bits.
Posted 27th Oct 2015 at 20:38
I've ran this past Mei several times & Spoken to Sandy Brown who says its possible as Mei has ....Middle of next year hopefully Thumbs up
Posted 28th Oct 2015 at 07:18
rallyeash
My brothers is a 88mm crank, 300ZX pistons and steel rods. Can't remember which ones. Sandy built it.
309 3dr K20 Type R
Posted 28th Oct 2015 at 11:13
rallyeash
Shock
You can't go over bore on a budget. I spent £1200 on my pistons and conrods.
309 3dr K20 Type R
Posted 28th Oct 2015 at 11:15
cully
ok ok maybe im getting ideas above my allowance Wink
i will get back in my box Yes
i think i should be enjoying the car i have and maybe put together another STD engine for when this one i built expires its doing good though its upto 2000 miles now Big grin
Posted 28th Oct 2015 at 18:47
