Author Subject: Running twin carbs
Ok so Ive purchased twin 45s for my 205 gti6 and now wondering how I go about getting them to run obviously I need to ditch the std ecu and loom but what do I go for instead ? Is there a plug and play system I can get hold of ? Assume I just need a loom and ignition ecu ?
Posted 17th Oct 2015 at 11:56
Would the standard ecu not work just without the injectors fitted?
Also, i could be wrong but when using carbs don't you need to use a low pressure fuel pump to fill the bowls rather than the standard pump setup? Dunno
Posted 17th Oct 2015 at 12:56
Comes with an fse fuel press regulator so guess that takes care of that car also has a walbro in take pump.
Posted 17th Oct 2015 at 12:59
fatlapit
Whats the carbs from??
Posted 17th Oct 2015 at 13:27
Webber twin carbs bud and were being used on an mi engine ?
Posted 17th Oct 2015 at 13:29
why the funk you you put carbs on a gti6 ?!
Posted 17th Oct 2015 at 15:06
Because they were cheap ! And I haven't done it yet but I don't see what the problem is going down that route ?
Posted 17th Oct 2015 at 15:16
Fair play if they were cheap, they've always been pretty expensive when i've seen them for sale in the past. Plus, that noise! Love LOL
Posted 17th Oct 2015 at 15:35
go bodies or go std.
Posted 17th Oct 2015 at 16:31
Well I'll give it a go hey see how it turns out
Posted 17th Oct 2015 at 18:03
monty-69
They should give power similar to bodies if they are jetted and everything is set up properly. Driveability should be ok. I cant remember off top of my head the jets in my 2ltr mi but i would go with 38mm chokes. There is a cracking book called how to build and power tune weber and dellorto carburettorsThumbs up
Posted 21st Oct 2015 at 19:31
