Author Subject: Knackered alternator?
matt16v
Hi gents,
Had some issues with the battery running down recently. With the car running I'm getting 12-13v across the terminals so presumably the alternator is on it's way out. Is there anything else I should check before chucking a new one in (£175 exchange for the Bosch one!)
1999 Astor Grey GTi-6 OEM+
Posted 11th Oct 2015 at 16:06
eddy_gti6
I have a good spare alternator if it's any good to you? £40 posted
Posted 11th Oct 2015 at 18:04
Yes check the terminals are tight. Then unbolt the earth wires and clean everything up.
You can check the earths are good by connecting a jump lead from the negative battery terminal to the engine/gearbox case then measure the voltage again. Might be worth checking the draw across the different earths too.
Seem to get a lot of earthing issues in 306s now they are getting older
Posted 11th Oct 2015 at 23:32
Check the positive lead on to the alternator is tight and clean too
Posted 11th Oct 2015 at 23:33
I can get you an alternator bud no probs but check all the terminals and earth points first 👍
Posted 12th Oct 2015 at 08:41
