Author Subject: Crank Hockey stick seals ?
Not on my 6 ....on my dirty diesel...Have got oil leak possible from front & rear Crank seals or Hockey sticks ?
Gearbox / clutch coming out being sorted on 3061.9 D this week & wondered if fitting two hockey stick seals is a straight forward job while flywheels off replacing rear crank seal Clucth etc ???
No one I knows has replaced the two hockey sticks ?...is it a horrible job ?
Any info from anyone who's done them ?
Any advantage with box removed or not ???
Posted 21st Sep 2015 at 12:12
cully
you need to drop the sump,oil pump and wind-age tray to give you easy access to the bolts as they are part of the end main bearing caps behind the flywheel
asumming the dirty diesel has a windage tray if not the oil pump wont need removing Wink
Posted 21st Sep 2015 at 12:49
no need to touch oil pump or windage tray.
diesel wont have windage tray anyway
Posted 21st Sep 2015 at 12:53
So really no advantage with the Box out Mei ?
Difficult job ?.....once Sump is off
Posted 21st Sep 2015 at 14:19
box will have to come out as flywheel will need to be removed to re-install the main crank seal
Posted 21st Sep 2015 at 14:47
Sorry Mei is that for the Hockey Stick seals ?
Taking the Flywheel off to do Rear crank oil seal !
Posted 21st Sep 2015 at 15:03
the main cap has to come off to do the hockey stick seals, main crank seal sits in the main bearing cap also.
http://www.306gti6.com/forum/showthread.php?id=115526
Posted 21st Sep 2015 at 15:20
Big thanks Mei makes sense now Thumbs up
Those hockey stick seals were less than £5.50 for the pair inc vat from main dealer Crazy
Posted 21st Sep 2015 at 19:49
should be less than a quid each.
Posted 21st Sep 2015 at 20:02
Well the 1.9 Dirty diesel lives again ....rear crankcase oil seal was fooked & inside the Bell housing from flywheel flinging oil everywhere apart from on the clutch itself ....
Clutch Bearing fallen apart & all bearings gone !!!!
All new seals & service plus new clutch kit & Fork bushes fitted with new clutch cable ....how smooth & light now Shock
Posted 22nd Sep 2015 at 17:50
blandy
Rather than start a new thread - did you put sealant on the sticks when installing?
After buying a tool etc I’m Addament the seal is spot on now. I did replace these stick seals also but again under the car in a rush,
How much do they stretch by? As mine seemed to stretch a lot and after leaving overnight hadn’t shrunk at all so I’m hoping there lies my problem. I did check the breather etc and with the gauze in with the cap pushed down it still breathes so rules that out so either I have a issue with these seals or the crank itself I reckon.
Posted 13th Oct 2018 at 15:48
quote:
[quote="blandy"]Rather than start a new thread - did you put sealant on the sticks when installing?
Never ended up having to do mine ....I know there’s a install guide on here Thumbs up
Posted 13th Oct 2018 at 19:16
blandy
There’s a few ideas around but nothing conclusive. I’m gonna take the engine out this time so will make sure it’s spotless and have another go.
Have a crank seal left as well which is a febi ptfe type seal so that’ll go in as well which requires everything to be spotless
Posted 14th Oct 2018 at 10:40
quote:
[quote="blandy"]There’s a few ideas around but nothing conclusive. I’m gonna take the engine out this time so will make sure it’s spotless and have another go.
Brilliant....keep me updated ....good luck Thumbs up
Posted 14th Oct 2018 at 10:53
