Hi, I would like to know if anyone can send me the complete list to Portugal? - Cam timming sensor
- Knock sensor and wiring ( green 3 pin )
- Oil level sensor and wiring (green 2 pin )
- Oil pump chain
- 2x the oil pipe that goes from the head to the block
- This pipe that cames from the head and goes to the block have 2 entrys, one of them is a big one ( right side of the oil filter) and have a metal bit that connects the pipe to the block... you can remove it with a plier.
- Inlet Cam cover and cap
- sump bolts
- engine crane mounts
- Drive shafts
- 2x Vacum pump pipes (vaccum pump to inlet manilofd and brake servo with the connector in the middle)
- lower engine mount arm and bearing
- 306 gti fuel relay (behind the ECU?)
Pedro
