Author Subject: 205 Gti6 questions
p-silva21
Hi guys,
As I know there are many threads here with awesome 205 projects and I´m currently building my first 205 CTI 1.6 with a GTi6 engine, I have a few questions for you if possible.. So, I´m thinking to use a Gti6 engine with a 1.8 16v gearbox that I have as a spare..
- Can I use the 1.8 16v (XU7JP4) flywheel and clutch (as they are a pull type) to suit the engine?
- I have the 1.9 Gti hubs already to use Gti6 brakes. Can I use a Gti6 driveshafts or a hybrid 1.6 original one?
- Does anyone have a Gti6 to 205 conversion wiring loom for sale at a good price?
Thanks
Pedro
Posted 15th Sep 2015 at 15:29
1.8 is a push clutch, get a 1.9 MI16/bx16v clutch on the gti6 flywheel, 1.8 flywheel is only 200 mm clutch, gti6 and mi16 is 215mm.
what?
not me. easy to do though.
Posted 15th Sep 2015 at 15:06
p-silva21
- Many thanks
- Sorry I meant to say driveshafts not transmission..
- Thanks anyway mate
Posted 15th Sep 2015 at 15:18
the wiring loom is a piece of p**s to do yourself. there's a guide over on 205gtidrivers with the pinout and wire information
as said, 1.9 mi16 clutch
gti6 brakes are fine with the 1.9 hubs and 1.9 shafts
Posted 15th Sep 2015 at 15:28
p-silva21
Ok, thanks for your replys Thumbs up The only thing I need to know is if there are any other options about the driveshafts.. Do I really need to use the 1.9 or can I also use a Bx 16v or Gti6 ones?
Posted 15th Sep 2015 at 15:33
any shaft other than 205 (or 309 if using 309 wishbones) will be too long.
Posted 15th Sep 2015 at 16:23
p-silva21
And can I use the standard 1.6 shafts in 1.9 hubs and 1.8 16v gearbox or will I need specifically the 1.9 shafts to use with 1.9 hubs? Also, will I need to use the 1.6 diff to run these or the 1.8 16v one is just fine? Thanks for your help!
Posted 15th Sep 2015 at 17:16
1.8 diff will be fine, 1.6 shafts will only fit base model and 1.6 hubs. you need 1.9.
Posted 15th Sep 2015 at 17:26
p-silva21
Ok, all solved then... The only thing I need to know now is if does anyone have some 1.9 driveshafts for sale! Already sorted a Bx 1.9 clutch
Posted 15th Sep 2015 at 17:53
I have 309 Gti shafts and lower arms ?
Posted 15th Sep 2015 at 18:05
p-silva21
PM´d Thumbs up
Posted 15th Sep 2015 at 18:10
MUST be a 16v clutch, not 8v.
Posted 15th Sep 2015 at 20:32
