Author Subject: WTB few parts
my3AWDgst
My engine was damaged in shipping that I was waiting for seven months so I'll list everthing bellow what I need.
I'm located in California US and I would preferred to purchased all items of one seller preferably out of part out.
1) Exhaust side valve cover and camshaft bearing bed with hardware.
2) One ignition coil,ignition coil pig tail and ignition coil cover.
3) Brake booster hoses and check valve.
4) Vacuum pump that is bolted on back of exhaust cam.
5) Passanger axle assembly.
6) Clutch fork retaining pin.
7) Engine relay box that is near ECU.Fuel pump relays?
8) Throttle cable.
9) Purge valve.
10)Body side to engine harness pig tail and OBDII plug-pig tail.
11)Breather hoses and PCV (black box that goes to V/C)
12) Oxygen sensor.
Aslo would you please advise where could I get following new items.
1) Both axle seals.
2) Input shaft seal.
3) Clutch fork bushings.
4) Spark plugs.
5) Intake manifold and throttle body gaskets.
6) Roll stop engine mount insert.
7) Injector seals.
8) Thermostat.
Thank you.
Savo Stanivukovic
90 405 Sport Wagon 306 GTI 6 swapped.
89 405 MI16 ECMlink,SD,E85 swapped.
89 405 MI16 (standard)
91 405 MI16 (Sorento Green)
91 405 MI16 parts car.
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
2010 Genesis coupe track edition.
Posted 3rd Sep 2015 at 01:15
my3AWDgst
1) Both axle seals.
4) Spark plugs.
7) Injector seals.
8) Thermostat.
I end up getting these items from Germany.
Thank you.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 5th Sep 2015 at 13:52
injector seals - mr injector.
thermostat - local auto parts store
plugs & driveshaft seals & input shaft - parts store
possibly also intake gasket
t-b gasket cluth fork bushes engine mount - Peugeot/citroen
Posted 5th Sep 2015 at 15:15
my3AWDgst
I live in USA so local parts store won't have any of those parts. I end up getting them from Germany,same person that I purchase my 405 parts from.
Also we don't have Peugeot/Citroen dealer or parts store since 1991.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 5th Sep 2015 at 22:20
RetroPug
Dealers in the UK may be willing to post?
As WP said, mr.injector in the UK do very cheap injector overhaul kits or just seal kits. Possibly google them and see if they'll ship to you?
Posted 6th Sep 2015 at 08:12
my3AWDgst
I end up getting everything from Germany including new O2 sensor.
Thank you.
Anyone has any of the used parts I'm after?
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 6th Sep 2015 at 23:39
my3AWDgst
Thank you.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 7th Sep 2015 at 00:04
my3AWDgst
Still looking for:
1) Passenger axle assembly.
2) Throttle cable.
3) Purge solenoid.
4) Body side to engine harness pig tail.
Thank you.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 18th Sep 2015 at 14:32
my3AWDgst
I received it all today,thanks for the space.
Savo Stanivukovic
91 405 Sport Wagon.
99 AWD Spyder.
98 AWD Spyder
Posted 1st Oct 2015 at 00:56
