Author Subject: Strange issue i have encountered
fatlapit
Some of you may know i blew 3rd at fcs. I have changed my box. Easy bit done. So i fire her up and shes horrible and not happy. Miss firing not idling being a general pita. So i think vacuum leak and wiring. Either aomething ive not connected or somethings not tight. Nope non of that. So then i started to pressure test all the componants engine side of the tb. Er no problems. So i put her back together again. Still being a b**ch. So i thought hmmm ill plug the laptop in. Nope everything fine there. ffs wat can it be. So i started speaking to my next door neighbour. He says youve not get anything sensetive close to the fly wheel??? No i dont think so. So any way put her away thought nothing of it. So the next day i wiggled some wires and boom fixed awesome i thought. Took her for a test drive. Everything fine on boost iff boost and cruise all spot on. So i thought get home n wash her. So she decided to play up. This time fine on boost horrible for everything else. I get home let her cool and open the bonnet. Instantly looked at the flywheel area. Crank plug sitting right where a plastic bung for the bell housing should be. So i un plugged it and re routed the wiring. Turn the key and shes spot on.
Who would of thought thats the fault?? Must of been scrambling the signal. Totally crazy.
Posted 29th Jul 2015 at 19:51
rich_w
The crank sensor is very prone to interference being a hall effect sensor. They have a shielded twisted pair cable as standard. What cable has been used on your new loom? If it's not a shielded cable with seperate earth into the ECU for the crank sensor that will be the issue Smile
Contact Details:
07732 822546
Posted 30th Jul 2015 at 18:45
fatlapit
Its a standard omex loom bud. Ive just re routed the wiring.
Posted 30th Jul 2015 at 18:57
rich_w
It would be worth checking to see if you wiring is shielded. Also check to see the cable on the crank sensor isn't damaged Smile
Contact Details:
07732 822546
Posted 30th Jul 2015 at 21:35
Check the connectors in the plug too as they can push back into the plug
Posted 30th Jul 2015 at 21:48
fatlapit
Well ive had it plugged in and 2 more sensors. Gotta be the flywheel effecting the signal
Posted 30th Jul 2015 at 21:59
