Author Subject: The window do not go up / down after change of window lift
mughal
Hello.
I live in Norway, and need some help with my car.
It's a Peugeot 306 GTI-6, left-hand drive (3 doors).
I changed the complete window lift motor on driver's door. The reason for the shift was wire began to be destroyed.
After i changed the window lift, I mounted on the connector. I had to change the connector becuase the old connector did not fit on the new one.
After I installed the connector, the window lift did not work. The window on the passenger door worked just fine 3-4-5 times, but suddenly it also cut out. I heard clicking in the black box that sits above the window lift motor on the driver's door, but after few seconds i didnt hear the clicking.
Fuses are ok, and I get adjusted mirrors on both doors, they are electric.
Central locking and alarm also works fine.
I dont have an voltmeter, but I have a test lamp.
It does not light up when I put the test lamp on the terminal to window lift motor, neither when I try to take the window up / down, nor of the switch to take the window up / down.
I took off the round connector that goes into the driver's door, and there it glows in the test lamp in one connector. Wiring in the door was by the way changed for couple of years ago.
I do not have the wiring diagram for this, but I suspect that the "black box" that sits right above the window lift motor is defect, becuase I heard the clicking sound from it in the start, and then the window on the passanger door worked (couple of times).
I have checked with my local Peugeot dealer now, and the part is not available. The part number for this box is: 6547 Z5.
Does anyone have an tips on what the problem could be? And if it is the black box that is defective, is there anyone who can provide the box?
I hope someone can help me with this problem.
Sorry for my bad English.
mughal has attached the following image:
Moeen S. Mughal
Posted 22nd Jul 2015 at 07:24
mughal
Can anyone help me with this problem?
Moeen S. Mughal
Posted 22nd Jul 2015 at 07:30
Bobeek
broken wire(s) between the chassis and the door? quite common 306 issue..
Posted 22nd Jul 2015 at 21:19
mughal
The wires was changed for couple of years ago.. Or do you mean the wires inside the door?
Moeen S. Mughal
Posted 22nd Jul 2015 at 21:27
years? probably need checking at the very least
Posted 22nd Jul 2015 at 21:31
mughal
I think it was changed In 2013, it was an Peugeot workshop who changed it...
Moeen S. Mughal
Posted 22nd Jul 2015 at 21:40
mughal
Does someone has this box, if yes, can I buy it?
Moeen S. Mughal
Posted 23rd Jul 2015 at 06:07
Bobeek
try in the "wanted" topic...or ebay.. Wink
Posted 25th Jul 2015 at 11:27
mughal
Ok, thanks.
Moeen S. Mughal
Posted 27th Jul 2015 at 07:33
mughal
Problem solved, bad wiring in the door.
Thanks for help Smile
Moeen S. Mughal
Posted 8th Aug 2015 at 21:15
