Author Subject: Newbie with 306 GTI! Loads of questions!
BigRez
Hi all
A great site and community!
Finally after many years I've got myself a GTI6! I wanted one at University but obviously couldn't afford it, so all these years later I have one!
What a great great car. I bought a Phase 3 in Diablo red with 79K and almost 1 lady owner from new. I know my cars well, and this one is a peach. I cannot imagine many of these are left now with such extensive history and completely standard!
I have some urgent questions I hope you guys can help with. I'll list them below;
1 - Tapping! Belt snapped before the second change in 2011 due to pulley failure. The car has been to the same Peugeot specialist for 12 years and everything is documented.
They took the head off, fitted 16 new valves and built the lot back up with gaskets/belts/water pump etc to the tune of £1500!
How can I be tapping with all that lot done? The ladies husband said it's been like that since the head job all those years ago and was claiming its down to the bucket and shim clearances; I promptly informed him the engine has hydraulic tappets!
Not the worst noise in the world but still well annoying.
Anything I can do? Kind of sounds tappet like?
2 - Cambelt is due! I don't know any Peugeot people at all (usually buy BMW's/Hondas) so I'm a bit stuck! The belt kit is cheap from ECP as is the water pump but I'd like someone to do it privately to save costs.
I'm based in Essex.
Does anyone know of hands on 306 home mechanics who can do this on a Saturday morning for me? I don't mind travelling chaps.
3 - Coolant! Just wondering what coolant these cars take? Red or Blue?
4 - Rear shocks! The car saw a major front suspension rebuild recently including shocks, springs, lower arms, track rods, drop links etc but the rear dampers, as good as they feel, might be worth changing.
What rear dampers to get?
Bilstein B4
Bilstein B6
KYB Ultra SR
KYB Excel G
5 - Clutch cable! There are so many listed for the 306 I'm struggling to find the right one. It all works fine, its just the pedal is heavy and feels like the cable is really taught in the sheath.
Anyone know where to get one? Again, can anyone around Essex fit this for me for a fee? I know you guys will have done this before.
Appreciate your responses chaps.
I hope I can chip in as required.
Rez
Finally got a GTI!
Posted 18th Jul 2015 at 21:31
pebbles167
My opinions:
1. Engine tapping - They usually tap a bit. If its overly loud then investigate further, otherwise just leave it.
2. Cambelt fitting - Several members in the area on here, although it's a bit of a painful job. Stan perhaps? Otherwise, a good indy.
3. Coolant - Water. Antifreeze. Type matters not.
4. Rear suspension - Standard dampers seem fine unless you are intending on more mods. Even then, not too shabby.
5. Clutch cable - They are often stiff, think they run close to the exhaust and dry out. Go to any independent garage for a new one.
2005 Peugeot 206 GTI 180
2008 BMW K1200R
Posted 18th Jul 2015 at 22:09
BigRez
Cheers bud.
Yeah its certainly not a loud 'tap'. Sounds almost like an injector tap? Could be a tappet I suppose.
Stan if you are around please PM me buddy.
I'll check the fronts and if they are B4's I'll just get a B4 set for the rear.
I hear the clutch cable is a b**ch; I'd rather a forum member would do it for me whilst I helped.
Finally got a GTI!
Posted 18th Jul 2015 at 22:14
Can be tappets. If it's done that many miles then it's probably a tappet, mine needed four replacing.
I'd use standard Peugeot over kyb or b4, b6 if you need more control.
Welcome Smile
Posted 18th Jul 2015 at 22:53
aaron6
Armzs16 on here works at a pug specialist in kent/sussex and does all my maintenance. He knows his s**t and could sort it.
Mine has a few noisey lifters but the tap goes after 5 mins. If your tap never goes it's most likely a few bent valves done whilst fitting the new head. Only cure would be to replace the head or engine.
Posted 18th Jul 2015 at 22:55
BigRez
Hi chaps
I'd be surprised if it's bent valves after replacing all 16! This was a proper PUG only specialist that the owners have known personally for well over 20 years.
UNLESS of course they charged for 16 valves and didn't actually replace all of them....
Anyone know where I can get armz or Stan as mentioned above?
Finally got a GTI!
Posted 18th Jul 2015 at 23:07
miles
Rarely clutch cable, the Cross shaft (Clutch arm) get's rusty and the top and lower bush's wear, replace those along with a clutch and it's pretty light, Not Ford light thou
www.pugracing.com
Posted 18th Jul 2015 at 23:15
BigRez
Thanks Miles.
Not a cambelt do'er are you chap?
Finally got a GTI!
Posted 18th Jul 2015 at 23:22
Nope.
Mine was as bad all the time and was tappets. Bent valves and guides would fail fairly quickly
Posted 18th Jul 2015 at 23:33
midlife
BigRez wrote:
Hi chaps
I paid £2.2k years ago for an engine rebuild on a non-tapper from a "Peugeot specialist" it came back a tapper!
When I got round to rebuilding the head myself I found 2 bent valves.....
They must have cocked up the timing I guess or been really slapdash when they were putting the cams back in.
When finding a mechanic (which you'll need now you own a 6) look for one that's really anal & enjoys working on Pugs, believe me really good ones are rare!!
Cool
Team 330™Cool
Team "no front end or engine"
Posted 19th Jul 2015 at 22:15
rich_w
I can do the belt, and sort the clutch and head out if need be - although I'm based near Portsmouth.
The head could be tapping for a number of reasons - most likely the valves.
People often re-fit the head with the cams fitted, this is the worst thing you can do - catch a protruding valve on the block, more than likely it will get bent. Also the valves foul each other if you turn the cam sprockets independently. It could also be a guide or seat issue.
Smile
Contact Details:
07732 822546
Posted 19th Jul 2015 at 22:26
This....
Rare to find these with lifters completely gone like Adams.... Usually they tap on and of from cold of its lifters then quieten down once warmed up. Of it never goes and has been like it since they did the rebuild either as rich said they refitted the head with the cams in which means a least 4 vales were pertruding when they lifte the head on and either they slightly caught 2 on the block or the valve guides were also damaged during the belt faliure and weren't changed. Could also be the valve seats weren't recut when the valves were replaced or they clashed the valves when fitting the belt.
Once they get higher mileage they all tap a little bit but not loudly. Mine is almost silent the Bosch 440cc injectors are louder than anything else. Then As far as "any coolant will do" never mix pink with blue or green as it will crystallise...
Posted 21st Jul 2015 at 22:08
matt16v
Probably not much point replacing the rear dampers unless they're buggered. It's likely the rear beam will need replacing if it hasn't been done before now. Replace the dampers then.
1999 Astor Grey GTi-6 OEM+
Posted 22nd Jul 2015 at 08:19
Chr1sch
Mine is on 160k and had a head rebuild from RichW back in 2011 at around 150k - its quite a noisy engine in general from my experience - now i've stripped it out its frankly terrifying what noises you can hear!
Posted 22nd Jul 2015 at 09:57
mik
I've just replaced my rear shocks with OE Pug ones. The factory suspension is very good unless you are making it into a track monster.
Great to hear about your purchase, sounds nice with good history.
Find a good mechanic to look after it - as someone else said they are hard to find!
Cherry Rallye SOLD
Posted 22nd Jul 2015 at 20:01
