Author Subject: Clutches & Gearboxes
Chr1sch
Hi all,
So as you may have read, i've stripped the interior in preparation for the Satchshift - all v exciting...
Today i managed to drive the car for the first time without sound proofing etc and i was slightly alarmed - my gearbox whines its tits off!!
Is this normal or is it about to die a horrible death? (its done 160k...)
Also, clutches, in the heat today it became both a little lazy to release and also bite further toward the top than previously, i've always thought the clutch would need attention so i'm not alarmed but trying to sense what is normal behaviour? - Do they bite at the top when worn? Is the whining likely to be the associated release bearing?
Cheers gents
Posted 3rd Jul 2015 at 19:21
The bite changing will probably be down to the adjuster in the cable becoming very hot and sticking.
As for the whine from the box itself, no they don't normally do that, get a second opinion.
It might be worth getting the box reconditioned, along with new clutch and cable - then you'll be good to go for a while yet. Smile
Stan.
Posted 4th Jul 2015 at 09:00
Chr1sch
Yeah I assumed as much, I changed the cable which helped enormously but the box itself is a much bigger job, is that quite an expensive job?
Posted 4th Jul 2015 at 09:45
If you're looking at someone to remove/refit box and change clutch you're probably looking around £200 labour.
Reconditioning the box would probably be around £300-£500 on it's own, depending on where you go.
Posted 4th Jul 2015 at 20:14
