Preference is to run a 15" wheel so that might limit my options even further...
Is what I've got the only option?
Craig
| Author | Subject: Brembo set up. |
Craig g
Regular Location: Edinburgh Registered: 23 Sep 2011 Posts: 149 Status: Offline |
My Rallye when I bought it came with brembo calipers running 288mm discs. I was considering changing these over to a wilwood set up I've left over from my 205 gti6 days but was wondering what the alternatives would be if I kept the brembo caliper set up in terms of disc options...Preference is to run a 15" wheel so that might limit my options even further... Is what I've got the only option? Craig |
yes.a select few 15" wheels will go over them, changing the discs wont make any difference unless you move the caliper too, clearance wise theyre quite similar to the wilwood kit ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Craig g
Thanks... Hopefully they fit over the Speedline SL2118's I've just bought! |
I hope you meant UNDER ![]() They did fit under the Magnesium version of that wheel, the 1508's, also Team Dynamics pro race 1.2. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Craig g
I meant under! Doh....👍 |
They needed a 3mm spacer on the btcc 15s speedlines________________________________________ Nothing to see here |
Craig g
Where's the best place to get 3mm spacers from? |
aaron6
Probably a machine shop. I made my ones. Which tbf I don't use now. If your at pugfest you can pick them up from me.________________________________________ See the sheer power and might of the lesser known burrowing owl. |
Craig g
Thanks for the kind offer... Unfortunately I won't be at pug fest!I'll get a set made up then if not available off the shelf. Although I think I might still remove the brembos and go with my wilwood set up as the brake squeal from brembos is a tad annoying! |
